Asset Type/Sector Updates
Postby John Lea » Sun Mar 21, 2021 7:41 am
I added some new securities to a watch list and when I tried to get the sectors and asset types using Internet Retrieve, it returned “unclassified”. I entered them manually but when I added a new stock and tried Internet Retrieve to update sector and asset type for it “unclassified” was returned and the manually entered ones were changed to unclassified. I must be missing some setting. Using Morningstar according to the log.
Will someone point the way. Thanks.
John Lea
Postby Mark » Mon Mar 22, 2021 9:03 am
Hi John Lea,
The stock updates of asset/sector from Morningstar are no longer working. Notice when you retrieve there is an option:
If Retrieve Fails
If you leave that set to "Change Investments to <Uncategorized>", that is what will happen, and it sounds like what you are describing. Instead, you can set it to "Leave investments un-changed".
Postby John Lea » Mon Mar 22, 2021 1:12 pm
Bingo! Thanks, Mark.
John Lea
Postby Mark » Tue Mar 23, 2021 1:24 pm
Hi John Lea,
The Asset and Sector retrieval for stocks from Morningstar is working again.
