Help! Suddenly can't save portfolios!
Postby DavidJ » Fri May 07, 2021 2:25 am
Hi!
The last week or so, every time I try to save a portfolio I get the following error message:
"The process cannot access the file because it is being used by another process."
How do I fix this?
David.
DavidJ
Postby Mark » Fri May 07, 2021 11:12 am
Hi David,
Can you think of any reason your *.mm4 file would be open in another program? Is it maybe being backed up, or is it saved on a cloud drive? Have you tried re-starting your computer? If you can't find what else is blocking access, you could use "File / Save Portfolio As..." and give it a new filename.
