start over from scratch
Having suffered what appears to be a very messy data corruption and having worked through all the usual recovery steps unsuccessfully, how may I start over with a clean slate? i.e. fresh install and setup as though I had never used the program before.
Hi davepapaz,
If you uninstall the program that will remove the program and all your preferences. You can then install it again, and start fresh.
Who is onlineUsers browsing this forum: No registered users and 21 guests |
