FMS update issue
Postby osinv » Thu Jun 10, 2021 12:32 am
I moved and restored FMS to a new laptop a couple days ago, it's a Macbook with the new M1 processor and I am using parallels virtual machine. Everything seems to be running fine until I tried to download a FMS update yesterday when I got this error message.
Any fixes?
Oscar
osinv
Postby Mark » Thu Jun 10, 2021 6:19 am
Hi Oscar,
Is that file there? The FMAdmin.exe file is responsible for getting updates when you request them. It should be installed to the same folder as your FM.exe file, and you need to be able to run it as an Admin. You might make sure you "installed" FM to this folder, and not just copy the folder from your old computer.
Postby osinv » Thu Jun 17, 2021 11:28 pm
Thank you Mark, there seemed to be an issue with the Parallels/Windows configuration that is fixed now so everything is working.
Oscar
osinv
Users browsing this forum: No registered users and 23 guests
