Portfolio Daily Totals Report?
Postby dellwo » Thu Oct 07, 2021 3:55 pm
It's probably obvious but...
you know how you hit F5 (All Data) and can see a table for each investment including the total value for every day.
Is there a way to view portfolio total value like that? There are too many data point to hover my mouse over the chart (it only shows every ~10 days). And if I do the portfolio report, it only shows one day at a time. I'd like a table with every day's total listed.
Thanks, Joe
dellwo
Postby Mark » Thu Oct 07, 2021 8:46 pm
Hi Joe,
This isn't available in the Data Register, but here are a couple options:
1) Use a "Portfolio Value" graph
or
2) Use "File / Export / Other / Portfolio Value..."
Postby dellwo » Thu Oct 07, 2021 10:12 pm
That's too bad. Just wanted a quick way to compare previous several days or more.
As mentioned, the chart has too many points so hovering only gives value of every 10th day.
No big deal.
Thanks, Joe
dellwo
Postby Mark » Fri Oct 08, 2021 9:13 am
Hi Joe,
Some other ideas for this...
1) Zoom the graph in, so it only shows the last month or so, so you have better resolution on the recent days you're interested in. A quick way is the date drop-down in the toolbar, or a Shift-Mouse drag will also do a date zoom.
2) Create a Custom report with 6 dates and only show the End Value. Memorize it for easy recall.
Postby dellwo » Fri Oct 08, 2021 9:56 am
Thanks... the report was what I was looking for. Took a bit to figure out the settings.
dellwo
