Master Portfolio Deletion
Postby jackrsm » Thu Apr 02, 2009 6:39 am
How can a master portfolio be deleted?
jackrsm
Postby Mark » Thu Apr 02, 2009 8:22 am
Hi jackrsm,
You can close everything in your top level sub-portfolio, but you can't delete it. To remove everything, highlight your top level sub-portfolio (named "Master Portfolio" by default) on the left side in the Portfolio Editor. Now, on the right side, it will show everything in this sub-portfolio. Select everything on the right by left clicking on the first item, hold down Shift, and left click on the last item. Select "Edit / Close".
Another way to accomplish this same thing is to close your portfolio file. Use "File / Close Portfolio", and that will close everything currently open.
