question to existing users before I purchase
Postby dmasvar » Fri Apr 03, 2009 6:09 pm
Hi
Just would like to know if this software and our entitlement as a purchaser to use on a different machine if buy a new machine as an example?
dmasvar
Postby Mark » Sat Apr 04, 2009 9:47 am
Hi dmasvar,
Yes, if you get a new machine, you can re-use your same license on the new machine. The rule is that you can re-use the same license key on multiple machines, as long as you are the only one using it.
