Portfolio Performance: N.A.
Postby chris319 » Mon Dec 20, 2021 11:59 am
In the Portfolio Performance report I am getting N.A. in the %Gain column for just one security. All of the other securities have what appear to be valid %Gain values. There is a valid value in the adjacent Gain column for the security in question.
What are the likely causes of the N.A. and is there a fix? I have checked the extrapolation period and found nothing amiss.
Thank you.
chris319
Postby Mark » Mon Dec 20, 2021 1:06 pm
Hi chris319,
Select "Help / Logs / Report Calculation..." and you should get an explanation. Let me know if you need further clarification once you read that.
Postby chris319 » Tue Dec 21, 2021 4:07 am
Mark wrote:Hi chris319,
There is no Report Calculation menu item in the Help -> Logs menu.
chris319
Postby Mark » Tue Dec 21, 2021 8:46 am
Hi chris319,
Make sure you are in the report in question, and then it will be there. If you're in a non-report window (Portfolio Editor or Graph), you won't see Report Calculation....
Postby chris319 » Tue Dec 21, 2021 4:04 pm
Here is what the log says:
Unable to calculate %Gain for TQQQ due to non-positive OOP basis (-66830.17)
Unable to calculate %Gain-V for TQQQ. Beginning value is zero or negative (0.00)
Unable to calculate ROI for investment CASH_BAL for dates 4/17/2017 - 12/21/2021. (Negative share balance for investment "CASH_BAL" between 4/16/2017 and 12/21/2021.)
Unable to calculate %Gain for CASH_BAL due to non-positive OOP basis (-24656.60)
Unable to calculate %Gain-V for CASH_BAL. Beginning value is zero or negative (0.00)
Unable to calculate ROI for sub-portfolio Margin Account for dates 4/17/2017 - 12/21/2021. (Unable to solve object yield equation)
Unable to calculate %Gain-V for Margin Account. Beginning value is zero or negative (0.00)
chris319
Postby Mark » Tue Dec 21, 2021 5:06 pm
Did you have any remaining questions after reading that log? If you're wondering about the negative OOP basis restriction on %Gain calculations, see the documentation here:
https://www.fundmanagersoftware.com/hel ... n_oop.html
The denominator of this equation is your OOP basis. As the OOP basis goes to zero, the %Gain approaches infinite. When the OOP basis is negative, the %Gain is reported as N.A..
Postby chris319 » Wed Dec 22, 2021 11:25 am
For some reason I can't make the N.A. go away.
Forget it. I'll use Excel to calculate my IRR.
chris319
