Upgrading to 2020 version
Postby carluzino » Wed Dec 29, 2021 7:49 am
Hi Mark, I think I have been using FM for more than 25 yrs and I hope it will never change. I am using version 2018.15.4.100 / quote module 564 and trans. module 251. I know there are newer versions and can see the long list of changes and bug fixes, but I am reluctant to change when something is working. Do I have to upgrade or I can continue to use this version? Are there any major/significant changes on the last versions?
carluzino
Postby Mark » Wed Dec 29, 2021 7:56 am
Hi caluzino,
You are not required to upgrade. However, quote/transaction module updates are only maintained for the 2 most recent major versions, which is currently FM 2018 and FM 2020. You can read more about this here:
https://www.fundmanagersoftware.com/faq_license_fee.php
and you can see the list of improvements here:
https://www.fundmanagersoftware.com/modlist.html
See the list under 2020.16.0 for most of the major changes in FM 2020, compared to FM 2018.
