Windows 11
Postby Chuck » Tue Feb 15, 2022 7:05 am
Mark, I am using version 2014 and although it is an old version it works perfect for my needs. It was time for a new computer with Windows 11 installed. I downloaded the older version, but am not able to open it. Message says something about needing an app to open a .php file. What do I need to do?
Thanks, Chuck
Chuck
Postby Mark » Tue Feb 15, 2022 9:57 am
Hi Chuck,
We have just released Fund Manager 2022 Beta, which has been updated/tested for Windows 11. I'm not sure why you're getting a message relating to a .php file. That seems strange, as Fund Manage has nothing to do with PHP. You can download the 2022 version here:
https://www.fundmanagersoftware.com/fm2022beta.html
If you have troubles running this version under Windows 11, please let me know.
Postby Chuck » Tue Feb 15, 2022 11:26 am
So, I downloaded the file again and it came as an .exe file. It opened and was set up with no problem. Go figure.
Thanks, Chuck
Chuck
