Removed old portfolio entries in menu File
Postby larryw » Sun Feb 27, 2022 3:58 pm
I have some old portfolio options to open in the Menu->File and listed at bottom. I'd like to remove those options since I no longer have those portfolios. Is there some way to remove them?
larryw
Postby Mark » Sun Feb 27, 2022 6:05 pm
Hi larryw,
Not from within the program. Those are just your most recently opened portfolio files. You can ignore them, or if you want, you can use "regedit" while Fund Manager is not running, to remove them at:
HKEY_CURRENT_USER\SOFTWARE\Beiley Software\Fund Manager\CurrentVersion\Recent Portfolio List
