Deleting a portfolio / start over
Postby Glenn Hall » Wed Mar 30, 2022 4:36 pm
I have the latest update and I have a problem with one portfolio that I can not get to function correctly. I do not associate it with the update to 2022 as the problem existed in an older version.
How can I delete that portfolio and it's contents and start over with a new portfolio with the same name without interfering with my other portfolios when I do an transaction update?
Glenn Hall
hall1inc@aol.com
Glenn Hall
Postby Mark » Wed Mar 30, 2022 8:50 pm
Hi Glenn Hall,
If you are referring to a sub-portfolio, you can just use the Portfolio Editor window. Right mouse click on the sub-portfolio, and "Close" it.
If you are referring to a portfolio file (*.mm4), just use "File / Close Portfolio" and then go about re-creating whatever you'd like. Use "File / Save Portfolio As..." when you are done.
