I have been using Sector labels on my stocks and at times don't know the sector so I set up something like AI or 5G which are not real sectors. I decided to go through and remove all the sectors that were not in use from over the years and put in actual sectors which is going to be a major task. While doing so I noticed you can use MorningStar or Yahoo sectors as defaults. My questions are:
- Can I backup my sectors that I defined?
- Then can I select MorningStar or Yahoo sectors and have FM over write all of my defined Sectors.
- If I would like to go back Can I then Restore my defined sectors to overwrite Morning Star
Jim
