Cannot Install Upgrade
Postby El Wealtho » Mon Apr 11, 2022 7:01 pm
Installation Aborted
Extract: error writing to the file dis.dat
File is NOT read only. Now cannot open old version of FM.
El Wealtho
Postby El Wealtho » Mon Apr 11, 2022 8:13 pm
Fixed it.
It was to do with Windows Security preventing "Controlled Folder" access. Had to allow the downloaded FM upgrade .exe file permission to access controlled folders. (The old FM.exe file had already been given permission when I encountered a similar problem as reported some time ago.)
I came across this fix by right-clicking the dis.dat folder > scanning with Windows Security.
El Wealtho
Postby Mark » Tue Apr 12, 2022 10:21 am
Hi El Wealtho,
Okay, glad you got it fixed, and thanks for pointing out the solution.
