hOW TO PUT SAME TICKER SYMBOL IN DIFFERENT PORTFOLIOS
Postby Larry Harter » Tue Apr 19, 2022 5:08 pm
HOW DO YOU PUT THE SAME TICKER SYMBOL IN MORE THAT ONE (DIFFERENT) PORTFOLIOS?
Larry Harter
Postby Mark » Tue Apr 19, 2022 5:10 pm
Hi Larry,
We have instructions for this here:
https://www.fundmanagersoftware.com/faq ... tments.php
Basically, you want to create a new investment for each holding of the same security. You save each investment as its own *.dat data file, so you can track the transactions separately.
Postby Arrow » Wed Apr 20, 2022 8:41 am
Hello Mark.
Is it it correct to say that when one creates a new investment FM assigns a new
*.dat data file name but if even if I change the name of the investment it will keep the same origninal name of the datafile only with a number 1 or 2 afterwards.
And if the above is true how can I find the correct name of the data file ?
Thanks fo your answer
Arrow
Postby Mark » Wed Apr 20, 2022 9:51 am
Hi Arrow,
When you create an investment, you assign it to a *.dat filename. That filename doesn't change when you change any of the properties of that investment (name, symbol, etc). You can change the filename, by using "File / Save Investment As..." if you want.
