Advice on fund categories
Postby dellwo » Fri Sep 09, 2022 12:50 pm
Probably dumb question but I'm trying to organize better.
What do you suggest ie for a High Yield Muni Bond Fund (looking at VWAHX)?
I see you can choose:
Type: No Load Fund or Bond (not both)
No Bond or Municipal etc to choose under other tags.
Should I do No Load Fund and add custom fields to Asset Type?
Or should I just call it a Bond?
Thanks, Joe
dellwo
Postby Mark » Fri Sep 09, 2022 2:40 pm
Hi Joe,
It is really up to you... You can also create your own investment types if you want to narrow down the types some. See "Options / Investment Type...".
Postby dellwo » Fri Sep 09, 2022 5:48 pm
I thought there might be a standard way.
So, I'm trying to figure out how to chart a single Investment Type or Asset Type.
I see Stacked Value->Investment Type but it shows all of them. Is there a way to plot one over time?
This started with me trying to see how my Bond funds are doing with the Fed rate changes.
Thanks, Joe
dellwo
Postby Mark » Sat Sep 10, 2022 11:11 am
Hi Joe,
Sorry, no, you can't plot just one at a time. It might be a nice feature to add the ability to filter some of the graphs like this.
