Is there any way to do calculations in the legend using inserted fields?
Thanks, Jim
legend text calculations
Is there any way to do calculations in the legend using inserted fields? Thanks, Jim
Also mark is there anyplace that defines what each of the fields that you can insert mean
Hi Jim,
You can't do math on the fields you can insert into the graph legends. You can do math using a User-defined field in a Custom report, when using the Pro/Advisor versions. The definitions of each field you can insert into the graph legends is shown in the bottom of the dialog box when you click on any of the fields. The selected field has its definition shown.
Who is onlineUsers browsing this forum: No registered users and 13 guests |
