reset to default?
Postby Erik » Fri Jan 13, 2023 11:27 am
My custom reports are gone.. Also, the font size is larger than I was used to. It looks as if everything has been reset to 'default' options.
I restored a backup to no avail. Strangely enough it only occurs on my laptop, FM on my PC seems fine.
Any idea what could be wrong?
Best regards,
Erik
Erik
Postby Mark » Fri Jan 13, 2023 4:27 pm
Hi Erik,
Your custom reports and fonts are stored in the registry. You might try restoring the "Global Preferences (registry values)" only from some recent *.FMB backup before this problem happened. You can choose to restore only this item during the restore, and not any of the other data files. To find your *.FMB files, see "Options / General Preferences... / Data" for the location of where your automatic backups are going.
Postby Erik » Sat Jan 14, 2023 4:24 am
Phew..it worked! I restored 'global preferences' (didn't even know that was an option), and everything seems back to normal :)
Thank you Mark!
Best regards,
Erik
Erik
