Hi Mark, unable to open file for write permission inteng14x.dll for quote module update.
Frank
quote module update
Frank
Hi Frank,
Are you using "Help / FM on the Web / Check for Updates..." to do this, or are you manually doing something? If you re-start your computer, and do this menu command first thing, does that resolve it?
Used Help function, also rebooted opened FM and tryed again to no success.
Frank
Hi Frank,
Do you have admin rights on your PC?
In what folder is FM installed? Can you go rename the inteng14x.dll and then try?
Installed on local disk C, program files (86), renamed file still no success.
Frank
Hi Frank,
Why don't you give me a call, and we can do a quick web meeting to see if we can't figure out the problem. 480-705-0129.
Who is onlineUsers browsing this forum: No registered users and 6 guests |
