Custom reports lost
Postby larryw » Thu Jun 08, 2023 7:41 pm
I've been running FM personal on my Mac under Parallels and that has been fine except it's really the only Windows program I really need/want in MacBook. I've installed Crossover to trial and installed FM which at the moment seems to work fine. The only thing is that it doesn't have all my custom reports.
Can I copy them from my Parallels installation to the Crossover installation? If so, where are they located under normal Windows install.
larryw
Postby Mark » Thu Jun 08, 2023 8:18 pm
Hi larryw,
Yes, you can. They are stored in the registry, which you can transfer via backup/restore. Please see these instructions:
https://www.fundmanagersoftware.com/newcomputer.html
Users browsing this forum: No registered users and 25 guests
