Moving TD Ameritrade account to new Schwab account
Postby dmorse147 » Fri Sep 15, 2023 7:36 am
Been trying to do this but Portfolio Value report shows new Schwab account with a negative shart value instead of positive share value. Numbers are correct for shares except for the negative sign. Any easy solution to this?
dmorse147
Postby Mark » Fri Sep 15, 2023 9:05 am
Hi dmorse147,
A couple of things to watch for when converting a TD Ameritrade account to Schwab:
- Use your existing Fund Manager TD Ameritrade sub-portfolio, and change the transaction retrieve properties and name. You don't need to create a new sub-portfolio.
- When retrieving transactions from Schwab you might (probably will) see a bunch of "Sell" transactions on the date of the move. You do not want to import these. I suspect they're an artifact of the conversion and you really didn't sell those shares, they just moved accounts. On the Preview Importing Transactions screen, un-check all of those false Sell transactions before finishing the retrieval.
For more info on using Charles Schwab - NEW, see the documentation here:
https://www.fundmanagersoftware.com/faq ... ersion.php
