Downgrading
Postby Septaj » Thu May 14, 2009 10:56 am
Hi there ....
More than happy to upgrade my FM Personal & will certainly do at least this.
Thought I might give Professional a go first. What would be the best approach, given that I may decide to go with an upgraded Personal over the Professional upon trying out the latter.
Best regards.
Septaj
Postby Mark » Thu May 14, 2009 12:36 pm
Hi Septaj,
The data files/format are all completely interchangeable between the different 9.x versions. So, any data you save in 9.x Professional can be read with 9.x Personal. You can download/install/use the 9.x Professional version, and if you later decide to stick with the Personal version, just download/install 9.x Personal right over that. You can continue on using your same data files.
