fm preference file, fmprefs.txt
Postby alciati » Thu Oct 12, 2023 5:22 am
HI mark
i moved to the new version Professional, congrats.
In the 2024 version installation folder there is not the file for preferences. normally i was overwriting with my old txt file, how can i use my old preferences settings?
i use the cloud saving with FM on One drive Thanks
alciati
Postby Mark » Thu Oct 12, 2023 8:23 am
Hi alciati,
Did you install FM to a folder where you have write permission as a non-admin user? You can't install to the Program Files (x86) folder if you want to use portable/cloud mode. The simplest is to just re-install FM right over your old installation. Don't uninstall your old version. If you had portable/cloud mode on before, it would stay on, with all your same preferences. If you want to install to a new folder, or happened to uninstall first, you can turn back on the portable/cloud mode at: "Options / General Preferences... / Data / Portable/Cloud Mode". For more on setting up the portable/cloud mode, see these instructions.
Users browsing this forum: Bing [Bot] and 11 guests
