Convert to common currency?
Postby DonMunro » Thu May 28, 2009 7:31 pm
Hi everyone,
I'm in Canada and have investments on the TSE, NASDAQ, and NYSE. I would like to know if there is any way that I can automatically see my portfolio values in Canadian dollars?
I do keep a dummy investment of the exchange rate [CADUSD=X on Yahoo], so the daily factor is stored within the FM data structure. I just can't see any way of applying the factor though.
thanks
Don
DonMunro
Postby Mark » Sun May 31, 2009 6:04 pm
Hi Don,
Yes, you can. You need to define the Canadian dollar as your default currency and specify your exchange rate investment under "Options / Currency Settings...". Then, turn on "View / Exchange Rate Adjusted". For a detailed tutorial on doing this, please see:
http://www.fundmanagersoftware.com/tutor_currency.html
Postby DonMunro » Sun May 31, 2009 11:00 pm
As usual, you have thought of everything :D
thanks very much.. I'll work through the tutorial tomorrow
Don
DonMunro
