Bank of Canada rate symbol and quote server
Postby gbenn » Fri Jan 19, 2024 3:30 pm
Just wondering if anyone knows how I can retrieve the Bank of Canada rate so I can create an investment to track this value. The Bank of Canada (https://www.bankofcanada.ca/rates/inter ... est-rates/) has this information. The symbol is V39078. Can the Bank of Canada be added as a quote server so I can retrieve this information? Is there any other way to get this info?
Thx
gbenn
Postby Mark » Fri Jan 19, 2024 3:49 pm
Hi gbenn,
I'm not sure if this quote is available on any of the quote servers, you'd just have to search. Maybe someone else knows, and can comment...
I did look at this site, and yes, it would be possible to add as a quote server. They also have downloadable prices, so if you did download daily prices to a CSV file you can use the generic price import with the options:
Specify Date: OFF
Specify Symbol: ON (and enter the symbol)
Input Format: YY-MM-DD,NAV
Postby gbenn » Sun Jan 21, 2024 12:56 pm
I downloaded the information as you suggested and this solves my immediate concern. I'll do a manual update of the interest rate as it changes, which is not very often.
Thx Mark
gbenn
