Lag(Not Reponding)-
Postby Bosox13 » Fri Jan 26, 2024 1:39 pm
needing some help
something is causing a unusual lag. It also reads (Calculating List Data)
any ideas what list data is? how to remedy?
thank you
Bosox13
Postby Mark » Fri Jan 26, 2024 2:32 pm
Hi Bosox13,
Which fields do you have displayed? See "View / List Columns...". Did you recently add any new fields to the list? If you turn off one field at a time until the problem resolves, which field is causing the issue?
