unknown Error
Postby 4Profits » Mon Feb 26, 2024 9:59 am
Mark ,
I keep getting the following error and have no idea what is causing it.
Bad Greeting. Socket error 10054, An existing connection
was forcibly closed by the remote host.
Any idea what this is or how I can track it down. What caused this?
Jim
4Profits
Postby Mark » Mon Feb 26, 2024 10:07 am
Hi Jim,
That sounds like an error that is happening when trying to send an email alert, and the email is failing. Check your alert settings under "Options / Alerts...". You can either turn off the "Send E-Mail Notification To:" option, or make sure your email settings are correct under the "Configure..." button. Use the "Test" button to verify.
