getting schwab access code hangs
Postby pdraganiii » Wed Feb 28, 2024 12:33 pm
been like this for 25 minutes. added a portfolio for a different company right before with no problems. i expected a browser to pop up like it now does for validation in quicken, but it did not. what can i try?
this is via parallels, if it matters
thanks
Screenshot 2024-02-28 at 1.29.51 PM.png (88.96 KiB) Viewed 5383 times
pdraganiii
Postby pdraganiii » Wed Feb 28, 2024 12:38 pm
more info: soft cancel doesn't cancel, stays hung. after a minute i hit cancel again, and the getting access code box went away and i was able to cancel out of the portfolio wizard
pdraganiii
Postby Mark » Wed Feb 28, 2024 3:29 pm
Hello pdraganiii,
I'm guessing it is some issue with running under Parallels. You're right, it should open up a web browser when you press "Get Access Code...". One work-around is to use a PC to get the access code as described here:
viewtopic.php?f=3&t=6333
Postby pdraganiii » Sat Mar 02, 2024 12:43 pm
I came back to it later, with a reboot in between, and it worked fine. I'll do that in first thing in the future if I have weird problems. Thanks.
pdraganiii
Users browsing this forum: No registered users and 28 guests
