Portfolio opens with tiny graph
Postby Septaj » Tue Jun 02, 2009 10:29 am
FM9.6.
Have used previous versions of FM for years with virtually no bugs. Quite frustrated with this version.
Upon opening, one of my portfolios now displays the proper graph but it is tiny and improperly rendered, positioned in the top left corner and about 8 times too small!
Thx
Septaj
Postby Mark » Tue Jun 02, 2009 10:35 am
Hi Septaj,
Are you maybe in the '9' display mode? Press the '1' button on the toolbar, or choose "View / Number of Displays / 1".
Postby Septaj » Tue Jun 02, 2009 11:39 am
ummm ... no. :-)
But I am not so worried by this at the moment. As I am unable to save my portfolio I cannot save the new settings that I am able to get in my session. In other words, the little shriveled graph keeps opening up but it is the same portfolio settings each time.
Thx.
Septaj
Postby Mark » Tue Jun 02, 2009 12:16 pm
Is the graph window itself small? If so, you can re-size it larger by clicking/dragging an edge. When you get the issue of saving your portfolio resolved you can save your portfolio and it will then remember the size/position of the graph window when you save your portfolio.
