Removing unused portfolio from registry
Postby Traveller » Sun May 26, 2024 5:01 am
Since updating to FM 2024 I haven't been able to remove the volume.mm4 portfolio from the list. It's also the default portfolio that opens up every time I launch FM. I've followed the instructions posted viewtopic.php?f=3&t=6467&p=26147&hilit=registry#p26147 and even rebooted my PC but no luck. Always opens Volume portfolio no matter what I do. Thoughts?
thank you
Traveller
Postby Mark » Sun May 26, 2024 8:54 am
Hi Traveller,
Look at the properties of whatever shortcut you're using to start FM. Maybe you have a command line specified, pointing to that portfolio file?
Postby Traveller » Sun May 26, 2024 10:48 am
Thank you, that's exactly the issue.
Traveller
