Left Portfolio Window Issues
Postby heidiasst » Fri Aug 23, 2024 7:36 am
Good Morning Mark,
The list of Sub Portfolios on the left panel of my Portfolio Editor is shifting off of the screen.
Adjusting the window for size has had no effect on this issue.
It seems to be getting worse, the Broker Names are nearly gone. I can still see the account numbers.
How do I get this to shift back to the original view I had?
My trouble shooting has not been successful.
Heidi
heidiasst
Postby Mark » Fri Aug 23, 2024 8:45 am
Hi Heidi,
You can both "resize" and "move" a window. It sounds like maybe you need to "move" it to the right, so the full window is on the screen. This only applies if your windows are in the "restore" state. If they are "maximized", they are set to take up the whole FM window. You can also use "Window / Cascade" to put all the open windows into the "restored" state, and move and size them so they can all be fully seen.
Postby heidiasst » Fri Aug 23, 2024 8:49 am
Perfect! Problem Solved!
Thanks Mark!
heidiasst
