FM seems to be slow
Postby LungDoc » Tue Sep 17, 2024 6:43 pm
I believe that FM has been the best investment management software I have ever used. I've noticed recently that it seems to be running painfully slow. I did a fresh reinstall but that didn't seem to help. What do you suggest. What additional information should I provide to you. Thank you.
LungDoc
Postby Mark » Wed Sep 18, 2024 7:59 am
Hi LungDoc,
What operation are you doing when it is running slow? Is it retrieving prices? Refreshing the reports, or some window?
Postby LungDoc » Wed Sep 18, 2024 12:11 pm
Slow to generate any report. Price retrieval so slow that I give up. Slow to backup. my backup is to my hard drive.
LungDoc
Postby Mark » Wed Sep 18, 2024 12:15 pm
Hi LungDoc,
Try this:
1) Restart your PC
2) Start FM and close all the open windows. Under the top level "Window" menu, use "Close All Reports", "Close All Graphs", and "Close Portfolio Editor", so you just have a blank gray frame window, and no open windows.
3) Create a "Portfolio Value" report. Is this slow still?
Postby LungDoc » Fri Sep 20, 2024 5:11 am
FM back to its usual quick speed after I removed Dropbox. Thanks again all your help as usual. The new quote module is good
LungDoc
