Copy and paste in Investment Description
Postby pccnavy » Tue Nov 05, 2024 10:17 am
Just realized I've had FM at least 14 years, and still very happy with it!
Small non-high-pri bug I think.
I found that copy and pasting in the Description field for an individual investment is "kooky". Dunno, it doesn't work consistently, most of the time "Copy" - either by right-click and select copy, or by CTRL-C, often doesn't capture the value, and the same is true for Pasting. Even when trying to copy and paste values to/from another program like "Notepad".
On a rare occasion either copy and paste work, but it's the exception.
Just upgraded to 2024.18.7. Sorry if this is already being tracked.
Again, not a big issue at all, but thought I'd raise it. sincerely appreciate your hard work after all these years (at least 30 for you huh? Wow!)
pccnavy
Postby Mark » Tue Nov 05, 2024 11:03 am
Hi pccnavy,
Thanks for your continued/long time support. It is appreciated.
This sounds like another issue that was reported, where copying from certain controls isn't consistently working. We will have this addressed for the next major update, but it still exists in the 2024 versions.
