Portfolio Editor
Postby Bsrr » Sat Dec 07, 2024 12:20 pm
When I (right) click on the right side of the Portfolio Editor view where the column labels are I am not getting the dropdown that shows "Customize" or my Template choices any more. Can you advise? Thanks.
Bsrr
Postby Mark » Sat Dec 07, 2024 5:56 pm
Hi Bsrr,
I'm not sure. If you re-start your computer does that resolve the problem?
Postby Bsrr » Mon Dec 09, 2024 3:43 pm
I am running Parallels/Windows 11 on a Mac and I rarely reboot the Mac so wasn't thinking of this. I did reboot and all is fine. Thanks!
Bsrr
