Retrieval Problems
Postby Bosox13 » Fri Apr 11, 2025 6:12 am
I am trying to retrieve Vanguard transactions. I keep getting the error
Post HttpSendRequest
WinInet error code: 12002
Message: The operation timed out
I have unistalled and reinstalled in C:Program Files(x86)
I have a backup of the program/investments under OneDrive Folder, but didn't want to delete that data bc I have used program for 10 years, and have alot of time in those files. I am hoping that you can tell me what to do without losing my data
Thank you
Bosox13
Postby Mark » Fri Apr 11, 2025 7:26 am
Hi Bosox13,
The problem is not with your computer or Fund Manager. It is a known issue with Vanguard's OFX server not working for quite a while now. You can read more about the history of this issue in this thread:
viewtopic.php?p=27353#p27353
and there is a documented workaround for this issue here:
https://www.fundmanagersoftware.com/faq_vanguard.php
If you want to help, you can call Vanguard and tell them how important it is to you for them to fix this issue.
