Seasonality not the same between report and graph
Postby Djobydjoba » Fri Aug 01, 2025 4:28 am
There are some differences between the seasonality for an investment in the Seasonality report and in the Seasonality graph. For example, for a seasonality calculated by months the seasonality of the investment is not always the same for each month between the report and the graph. It seems not normal?
Postby Mark » Fri Aug 01, 2025 8:26 am
I took a quick look, and didn't see this problem.
1) Do you have the same ending date on the report and graph?
2) Are you calculating for the same number of years in the report and graph?
If you still have problems, maybe you can send me a single investment file that isn't matching, along with what date/years combination you're reporting on.
Postby Djobydjoba » Fri Aug 01, 2025 8:35 am
My bad, it's OK now, the ending date was not the same!
Users browsing this forum: No registered users and 23 guests
