Deleting Portfolios
Postby mikelemke » Mon Aug 10, 2009 10:47 am
Is there a way I can delete a portfolio so that when I click on the toolbar icon I do not see portfolios which I don't use anymore?
Mike
mikelemke
Postby Mark » Mon Aug 10, 2009 10:56 am
Hi Mike,
Which toolbar icon are you referring to? Is it the "Open Portfolio" icon, which is equivalent to "File / Open Portfolio..."? If so, this command simply lists all the *.mm4 portfolio files you have in the folder you're looking in. If you are sure you don't want the other portfolio files anymore, just delete them. You can even delete them from within the "Open Portfolio" dialog. Select them, and hit the "Delete" key on your keyboard.
