Backup issue
Postby Mike » Tue Aug 11, 2009 7:59 am
After reinstalling the program to my new system and importing the registry key for custom reports et al I have a problem with backup. I have to manually select backup and manually name the file. The message I get is "Cannot open xxxxxxx-1.fmb" I tried using that file name for one of the backups. No matter. Subsequent backups still returned the error message.
Mike
Mike
Postby Mark » Tue Aug 11, 2009 8:19 am
Hi Mike,
Do you mean the automatic backups are failing? If so, make sure the automatic backup directory is set to someplace that exists, and you have write permission into. See "Options / General Preferences... / Data".
Postby Mike » Tue Aug 11, 2009 11:27 am
I had checked Options/General/... after the reinstall. The location was correct but acting on your suggestion I re-entered the backup location. Magic, upon exit the autobackup worked as advertised.l
You can close this one.
Mike
Mike
