Asset Allocations
Postby WatchingMy$ » Fri Dec 14, 2007 9:04 am
Hello Mark,
I was wondering where the data for custom asset allocations is kept? I ask because I installed Fund Manager on my home computer and my work computer. At home, I entered in custom allocation data. I installed at work using a backup copy from home, but the custom allocations did not show up. Thanks!
WatchingMy$
Postby Mark » Fri Dec 14, 2007 9:12 am
Hello,
These settings are stored in the registry at:
HKEY_CURRENT_USER\Software\Beiley Software\Fund Manager\CurrentVersion\Asset Type Labels
You can use 'regedit' to view/export/import this key from one computer to another.
Postby WatchingMy$ » Fri Dec 14, 2007 10:00 am
Excellent! Thanks again Mark.
WatchingMy$
Postby rm_organ » Tue Aug 26, 2008 7:28 pm
Hey Mark,
I know this subject came up when I had to migrate to a new computer. I had some good data backups but the registry was not something I had backed up. Plus, I was moving from XP to Vista, so maybe that would not have done me any good anyway. I'm sure there are probably some technical reasons why you don't want to/can't do this, however, if these settings could be included in a data file to be stored with the rest of the data, that would simplify moving to a new computer and especially help when needing to go to a new op system.
Thanks for considering.
rm_organ
Postby Mark » Tue Aug 26, 2008 7:50 pm
Hi rm_organ,
The new backup feature of 9.0 does now include all your registry settings.
