Upgrade
Postby almanzi » Mon Dec 17, 2007 2:47 pm
I just upgraded to ver 8.8 from 6. Should it be installed into the same fundmanager directory. Will this transfer all investments, transactions, portfolios, etc to thenew version?
Please help.
almanzi
Postby Mark » Mon Dec 17, 2007 2:54 pm
Hi almanzi,
Yes, just install 8.8 right over your current 6.x installation. Do not uninstall the old version first. You can then just directly open your 6.x portfolios/investments using 8.x.
