Accidently "closed" the Master portfolio, can't ge
I scrolled down the "File" menu and accidently closed the Master portfolio with all my subportfolios and I cannot seem to get them back. Can someone give me a step-by-step instruction on how to get those files to reappear? Thanks!
Hi DH Latorre,
If you used the "File / Close Portfolio" command you can just re-open your portfolio. It is most likely listed towards the bottom of your File menu under the most recently opened portfolios. It probably is next to the 1) and right below the "Exit" command. Just select this, and it will re-open it. Alternatively, use "File / Open Portfolio..." and select your portfolio file to open.
Who is onlineUsers browsing this forum: No registered users and 10 guests |
