Hi Mark On Windows 7 when I try to close FM I get the error message Access denied when FM ask if I want to save data The only way to shut down the computer is to force a shut down with FM running.
Do you have a fix for that?
access denied
Do you have a fix for that? Lawrence Brandon
Hi Lawrence,
It sounds like you have some data files saved underneath Program Files. Starting with Vista, compatible programs can no longer write data files into the Program Files area. You'll need to move them to another location, like under "My Documents \ Fund Manager", and open them from there. For more on this, please read this FAQ: http://www.fundmanagersoftware.com/vist ... sions.html
Who is onlineUsers browsing this forum: Majestic-12 [Bot] and 8 guests |
