portfolio performance with zero value and rows and more
Postby schwarcz » Fri Mar 05, 2010 7:18 pm
sorry for the newbie questions but.
My portfolio performance report is showing rows where the investment was zero value through the period and I would like to suppress that.
The report shows multiple rows for the same investment (presumably representing different sub-portfolios). Is there a way to combine them?
schwarcz
Postby Mark » Sat Mar 06, 2010 12:04 pm
Hi schwarcz,
Please feel free to ask as many questions as necessary.
To omit investments with zero shares from a report you can either hide the investment, or use the option to not display zero shared investments in reports. For details on this, please read:
If you are listing by "Investment", you will get a line item for each investment. So, if you have 2 investments with the same symbol, you will get 2 line items. If you want to combine all investments with the same symbol onto a single line, list by "Symbol" instead. The option of what to list by is available in the Report Settings dialog.
Postby schwarcz » Sat Mar 06, 2010 2:13 pm
Thanks for the reply.
In the portfolio performance report I have selected "do No Display Investment with Zeo Share Balance Over Entire Report Date Range".
However, I still have rows that show both a zero beginning and end value displayed.
I have selected list by symbol rather than list by investment and I still have multiple rows for a given holding.
There must be something else for me to do that I haven't spotted.
schwarcz
Postby Mark » Sat Mar 06, 2010 2:26 pm
Hi schwarcz,
Do you have "View / Hidden Investments/Portfolios" turned off?
Do you have sub-total by sub-portfolio turned on in this report? If so, are the multiple listings in different sub-portfolios? If they are in the same sub-portfolio, or you have sub-totals turned off, make sure you have the exact same symbol recorded in each of these different investments.
Postby schwarcz » Sat Mar 06, 2010 3:07 pm
Ah ha. I did not have View / Hidden Investments/Portfolios" turned off.
This has fixed the rows for empty holdings.
With regard to the multiple rows for a a holding, it turns out if I subtotal by asset type (which is what I have been doing all along) it switches to list by investment and does not let me list by symbol. Why is this?
schwarcz
Postby Mark » Sat Mar 06, 2010 3:31 pm
Hi schwarcz.
Yes, when you sub-total by anything other than sub-portfolio, you can only list by investment. That is just a limitation of the features in Fund Manager. It doesn't support every possible combination of sub-totals and listing.
Postby schwarcz » Sat Mar 06, 2010 4:43 pm
That is pretty disappointing. I monitor performance by asset class.
schwarcz
Postby Mark » Sat Mar 06, 2010 5:25 pm
You can still monitor by asset class, you just can't list by symbol at the same time. You can either sub-total by asset type and list by investment, or you could turn off sub-totals, and list by asset type.
Postby schwarcz » Sat Mar 06, 2010 6:16 pm
Right, but if I subtotal by asset type then I am going to getting a separate row for each investment (in a different sub-portfolio) of the same equity. It looks like there is no way around that?
schwarcz
Postby Mark » Sat Mar 06, 2010 8:03 pm
Correct, if you want to sub-total by asset type, you must list by investment.
