Income Report
Postby Alivascu » Thu Jul 01, 2010 8:56 am
Why does the total header have NA next to it. I do not get totals in
months 3/6/and 9.? Have checked everything that I can see and they
all look right.
Allan Ivascu
Alivascu
Postby Mark » Thu Jul 01, 2010 9:34 am
Hi Allan Ivascu,
This will be the case if you have investments in different currencies, and you do not have the option "View / Exchange Rate Adjusted" turned on. This report won't add the amounts of different currencies. It needs to all be converted/displayed in your default currency before a total will be shown. Try turning on "View / Exchange Rate Adjusted" and you should get your total.
