REPORTS
Postby robert1 » Tue Oct 19, 2010 8:15 am
I have several sub portfolios set up under a Master Portfolio. When I try to do a Custom report, all the sun portfolios have been merged into 1 report. I want them to be displayrd by sub portfolio, which is how it was done in the past. What am I doing wrong?
Thanks !!
Robert
robert1
Postby Mark » Tue Oct 19, 2010 8:52 am
Hi Robert,
It sounds like you just need to check the option on the "Report Settings" dialog to "Subtotal By", and then choose "Sub-Portfolio". If you have the "Subtotal By" option un-checked you will get what you're describing.
