Batch Email Reports in Advisor Edition
Postby Chandeleur » Tue Nov 16, 2010 10:49 am
I saw in February that you said Batch emailing reports wasn't a functionality of FM at that time. Is that available now? I think that would be a wonderful upgrade.
Bryan
Chandeleur Investment Consulting, LLC
Chandeleur
Postby Mark » Tue Nov 16, 2010 10:56 am
Hi Bryan,
Sorry, no, that still isn't an available feature. You can do all your graphs/reports for each client, but you have to do one client at a time. If you haven't already looked at this feature, see "File / Send By Email...". You just create all the graphs/reports you want, and then use this command.
I do think this would be a good improvement, so we'll look into it for a future update.
Postby Chandeleur » Tue Nov 16, 2010 10:58 am
Thanks for the quick reply, Mark. Right now, with 24 clients, it isn't bad to do it by client. But, I would like to use this functionality frequently in the future if/when you can integrate it.
Bryan
Chandeleur
Postby Chandeleur » Mon Jan 10, 2011 11:17 am
Is there a way to send the reports in PDF format instead of JPEG when using the "Send by Email..." feature?
Bryan
Chandeleur
Postby Mark » Mon Jan 10, 2011 11:33 am
Hi Bryan,
Sorry, no, not with the "Send by Email" feature. You could print to PDF files, and then attach them to an email though.
Postby Chandeleur » Mon Jan 10, 2011 11:35 am
Thanks for the super-prompt reply.
OK. Adding that capability would be a HUGE timesaver. Do you think there's a way for me to adjust that on my end?
Bryan
Chandeleur
Postby Mark » Mon Jan 10, 2011 11:48 am
Hi Bryan,
No, I don't think there is anything you can do to change the "Send by Email" only attaching image files. That is pretty much hard coded into the program...
Thanks for the feedback.
