column headings
Postby neri » Tue Jan 18, 2011 8:59 pm
Mark-
Is there a way to use a font smaller than 8 pt in displays or to customize the title of column in report editor? I am trying to squeeze a lot into the editor window and find that the headings become unclear once the column width is reduced.
Alternatively, if the security field name field could be locked (like Excel fields), you could easily scroll through the full sized columns.
Suggestions?
neri
Postby Mark » Wed Jan 19, 2011 8:15 am
Hi neri,
You can set the font to any size you want. The standard font dialog may only list down to 8, but you can type in any size you want. Right above the font size list is an edit box where you can enter in a number.
The labels used for Portfolio Editor column names cannot be customized.
