I can't get all of my disclaimer text to show up in reports. I'm guessing the field is too small and cutting off the rest. Is there any way to change the field size?
Disclaimer - Advisor Ver.
Hi cheapsk8,
How many lines of the disclaimer do you see? Is it cutting off at the bottom, or right side, or where? The space required to display the disclaimer is calculated automatically, but it is limited to 15 vertical lines. Is your disclaimer maybe bigger than this? If so, you might try setting the disclaimer text to use a smaller font under "Options / Report Preferences... / Disclaimer".
Hi cheapsk8,
I think the carriage returns may not be getting accounted for in the algorithm used by Fund Manager to determine required vertical space. We may need to fix this. Let me check into this, and I'll post back here. In the mean time, if you want to try removing the carriage returns, you can see if that corrects the issue.
Hi cheapsk8,
I was able to reproduce this problem when the disclaimer text has carriage returns. We'll have this fixed for the next release.
