Category labels report
Postby michael » Tue Jul 26, 2011 8:10 am
Is there any way to print a report displaying the Investment Goal and Asset Type User Defined fields #s with their corresponding label text?
Michael
michael
Postby Mark » Wed Jul 27, 2011 9:35 am
Hi Michael,
Are you just asking for a printout of the 100 asset types or investment goals, in order, but not necessarily for any investment? If so, there really isn't a way to print this. You can view it under "Options / Category Labels..." but that dialog isn't printable. Is there some reason you're trying to print this list?
Postby michael » Wed Jul 27, 2011 1:58 pm
Thanks Mark.
I was just trying to print the list so I can make sure that the category labels are the same on both computers. The files are stored on Drop Box.
Michael
michael
Postby Mark » Wed Jul 27, 2011 2:15 pm
Hi Michael,
I see... Another option would be to print out the values from the registry. Use "regedit", and browse to:
HKEY_CURRENT_USER\Software\Beiley Software\Fund Manager\CurrentVersion\Asset Type Labels
and then you can print that key. The string values will show the original name under the "Name" column, and you're assigned name under the "Data" column.
