Select 2 out of various sub-portfolios for reporting
Postby rojeg » Tue Aug 02, 2011 9:55 am
Hi
Assuming I have the following structure
Main Portfolio
-sub-portfolio 1
-sub-portfolio 2
-sub-portfolio 2.1
-sub-portfolio 2.2
and so on.
Can I create a custom report consolidating, let's say,
sub-portfolio 1
sub-portfolio 2.1
or any other combination of portfolios and sub-portfolios?
Thanks for your help!
rojeg
rojeg
Postby Mark » Tue Aug 02, 2011 10:07 am
Hi rojeg,
Not as you have defined there... When you report, you must select 1 sub-portfolio and the report includes everything at that level and beneath. If you wanted to create a report with your 1 and 2.1 you could do this by creating link sub-portfolios. You would do something like this:
Code: Select all
Main Portfolio
  -sub-portfolio 1
  -sub-portfolio 2
    -sub-portfolio 2.1
    -sub-portfolio 2.2
  - My Group
    - Link to sub-portfolio 1
    - Link to sub-portfolio 2.1
Now, you can report on "My Group", and it will include the 2 you wanted. Link sub-portfolios are a special type of sub-portfolio that just mirror image any other real sub-portfolio that you select.
Postby rojeg » Wed Aug 03, 2011 6:31 am
Hi Mark
Thanks, this is what I was looking for.
BR
rojeg
rojeg
Postby rojeg » Mon Aug 15, 2011 10:06 am
Hi Mark
I have tried as you described to create a special "my group" structure which has a sub-portfolio linked to an existing sub-portfolio the way you described (and the sub-portfolio is appearing in purple color).
When I do a total portfolio value report it is still adding the "linked to" (mirrored) sub-portfolio into my total portfolio value (and therefore double counting). What am I missing?
Thanks for your help.
rojeg
rojeg
Postby Mark » Mon Aug 15, 2011 11:13 am
Hi rojeg,
When you create the Portfolio Value report, are you reporting at the "Main Portfolio" level, or at the "My Group" level? If you create it at the "My Group" level, it will only include what is in the "My Group" sub-portfolio.
Maybe what you want is to create your hierarchy like this:
Code: Select all
Main Portfolio
  - My Holdings
    -sub-portfolio 1
    -sub-portfolio 2
      -sub-portfolio 2.1
      -sub-portfolio 2.2
  - My Group
So, you can report at "My Holdings" to get all your accounts, or at "My Group" to get just the combination you want. If you reported at "Main Portfolio" it would not be appropriate, as you'll get "sub-portfolio 1" and "sub-portfolio 2.1" included twice.
Postby rojeg » Mon Aug 15, 2011 11:43 am
Hi Mark
Right, I did the report at the "Main Portfolio" level. I need to do the structure exactly as you mentioned in your reply by using the "My Holdings" (for all sub-portfolios) and "My Group" (for part of the sub's) as the structure (under the "Main Portfolio").
Thanks! Should have seen this myself!
Best
rojeg
rojeg
